TwinTurbo.NET: Nissan 300ZX forum - Oh wait...
Oh wait...
Stokens (AR)
on May 27, 2016 at 9:02 PM
Re: No accessory power and doesn't start
posted by Stokens (AR)
on May 27, 2016 at 08:56 PM
You said no accessory power too. I was thinking of a clutch inhibitor relay, hoping that might be your problem.
If I would have known addiction was this expensive
I would have seen a shrink a long time ago. --
BadZCar (FL)
AaronR
18:55:37 05/27/16
What's the battery terminal voltage? (n/m)
jzack
19:23:13 05/27/16
Re: What's the battery terminal voltage?
AaronR
19:34:49 05/27/16
With the car off it should only be about 11.6 or so.
jzack
07:46:20 05/28/16
Stokens (AR)
20:56:12 05/27/16
Oh wait... -
Stokens (AR)
21:02:15 05/27/16
Starter relay under the cover in the driver side wheel well.
DVDBURN (MD)
18:10:47 05/28/16
Re: Starter relay under the cover in the driver side wheel well.
AaronR
00:28:46 05/29/16
Is the smaller 12v wire @ the battery terminal broken off?
10:54:19 05/29/16
Re: Is the smaller 12v wire @ the battery terminal broken off?
AaronR
15:38:52 05/29/16
Bypass starter relay and test, also suspect ignition switch. (n/m)
16:46:36 05/29/16
Have you removed each fusible link and inspected closely?
YlwPrlZTT
19:58:08 05/29/16
Re: Have you removed each fusible link and inspected closely?
AaronR
20:14:57 05/30/16
Does the engine turn over when you crank it...
DVDBURN (MD)
20:23:45 05/29/16
Re: Does the engine turn over when you crank it...
AaronR
20:16:30 05/30/16
Sounds like a ground issue but...
DVDBURN (MD)
00:42:23 06/02/16
do you get ANY power inside whatsoever? Dome lights? If not
YlwPrlZTT
09:22:09 05/31/16
Check your battery positive cable all the way down.
pandamanz32
08:58:12 06/02/16
